Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: #%!@*^# Turbo lag.
    Nov 2016
    South Coromandel, NZ
    Angry #%!@*^# Turbo lag.
    After about 25,000 km with the 2017 VW Tiguan 2,0 TSI Hi-R-line, the one thing that annoys me the most is the turbo lag. Several times when driving onto a roundabout during heavy traffic, the car starts to move a bit (enough to actually be on the roundabout), then seems to almost stall, while the other traffic moves towards me, and other cars come dangerously close because of the turbo lag. I found this video from 2016, from our friendly Thomas.
    VW Tiguan R-line 162kw, Tungsten Silver Metallic, Titanium Black-Crystal Gray.
    ACC, DCC, AID, HUD, DAP, ALS, LED, DSG, TSI, LOL
    Adelaide hills, SA
    Hmm, annoying.
    But, how was the road test car before you bought yours? Or is it something that just developed?
    Nov 2016
    My car was the first series that entered the country, so I only tested the 2017 model Tiguan that the dealer(s) had available (with a lighter engine/transmission). Following the video and a response from Autogefühl, VW/Audi say that it's a matter of perception, meaning the dual-clutch would be shifting to make the operation faster. Seeing those cars coming towards me on the roundabout I think VW is making a marketing escape by stating it would be faster suggesting that the client would just think it would be slower...
    DSG-gate? ...
    Anyways, I've decided to bring it up as a serious issue with the VW/Audi dealer as it sometimes actually becomes dangerous.
    Feb 2017
    Gold Coast
    Hi TungstanR and I think I have noticed a similar reaction with my Tiguan.
    It is something that only occurs periodically and always when I have just about come to a stop but not actually stopped, and then accelerate ( or try to ).
    I my case, it feels like when moving off from a stopped situation with the STOP/START activated, which I try to turn off every time I start the motor.
    Anyway, it feels like the same sensation and as you posted, it is VERY annoying and somewhat dangerous, particularly as it only occurs now and again, so I am not prepared for it when it occurs.
    NOTE, every time it does occur, the first thing I do is check that I have deactivated the STOP/START function.
    Could the two be related?
    Not sure if this is exactly the same issue, however in my gen1 Tig I've experienced issues with the DSG in "D" when pulling off from low speed. The transmission short shifts from 1->2 and then will not shift back to 1st gear no matter how hard you hit the accelerator pedal. This is more of an issue rolling into an intersection or onto a round-about and then trying to get going quickly. If you're in 2nd gear and engine at 1,500 RPMs you will be off-boost and will not pick up until the revs get up to 1,700-1,800rpm.
    This is a "quirk" of the DSG programming in "D" that it won't shift back to 1st gear until you come to a complete standstill. The only fix is to flick it into "S" mode if you're going to be needing instant acceleration or hit the paddle shifter to force it to 1st gear. Alternatively get an aftermarket DSG tune which fixes this problem.
    Nov 2015
    We found the same issue when we test drove a 2011 Caddy Maxi Life TDI DSG, it is really scary (especially bad here in Canberra because we have a "small" number of roundabouts to deal with).
    The way I understand it is that the DSG "predicts" which gear that you need next and pre-selects it so that it has a very fast shift. However when it pre-selects the wrong gear then it takes a lot longer to get into the right gear. This works well in normal driving as it can predict the next gear you need but not so well at a roundabout because at a roundabout you are slowing down often to almost a stop (I assume the DSG predicts that you are going to stop completely, decides and pre-selects that you are going to need "gear 1" to take off from a stand-still) but then as you see the gap and you accelerate hard into it, the DSG is suddenly caught out having pre-selected the wrong gear (it probably needs "gear 2" give you the continued acceleration at the speed that you are still travelling) so then there is a lag when you hit the accelerator and it has to de-select "1" and re-select "2" before engaging it, it then launches into the gap because you have hit the accelerator harder in the meantime as the oncoming traffic in the roundabout starts to give you an almost brown underpants moment.
    During our test drive both my wife and I experienced this a number of times. It was very disconcerting and we decided to stick with a manual when we bought our 2011 Caddy Life TDI. A decision we have not regretted, as a bonus we dodged the bullet of all the problems that the DQ200 dry clutch gear box offered for unsuspecting owners.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Dec 2010
    Helensburgh
    This exact thing can happen if the brake pedal is accidentally pushed even a little bit. I always left foot brake in an auto and I have accidentally touched the pedal with my left foot and instantly there is no power. My Skoda was the same, why it is like this is anyone's guess.
    Dec 2010
    Helensburgh
    Quote Originally Posted by feenix74 View Post
    In hundreds of thousands of K's driving a DSG I have never experienced anything like that.
    The TDI's actually come with the higher torque DQ250 6 speed "wet" DSG. The Tiguan has the heavy duty 7 speed DQ500.
    But all DSG gearboxes have similar software/behaviour. "D" mode is set up for economy which is why it short-shifts gears and won't drop back to 1st gear until you're stationary.
    Nov 2015
    Yep they do now. Back in 2011 the Caddy 1.6l TDI came with the 7-speed dry DSG. For a number of years, my independent specialist VW mechanic would question whether our Caddy Life was the DSG and sigh with relief when I said it was the manual, at first I did not understand why, then I found out and we realised just how lucky we were when we went with our gut feeling.
    Quote Originally Posted by Ozsko View Post
    I am glad for you and I will defer to your greater experience. I can only speak from my one test drive experience with the DSG.
    I must admit, I was convinced that I would adapt my driving style to the DSG and overcome the brown underpants moment (I assume driving it semi-auto instead of leaving it in D may overcome the problem) but my wife was not convinced. I did try to talk her into it, because I wanted the Caddy Maxi Life 2.0l TDI320 which only came with the DSG.
